jonnyony
Desperately need a manual trans for E28 M20 - 260/5
I purchased a used Getrag 260/5 transmission a while ago but unfortunately it had a very noisy countershaft bearing. I finally decided to pull it apart and the countershaft is toast. This is my daily driver so I need to get it back on the road ASAP. Please let me know if you have a good, smooth shifting, noise free transmission for me!
Thanks.
Edited by jonnyony
The 260/6 fitted the M30 engines... Do you need that, or a G260/5 which was used with the M20s?
Pretty sure they all do that...
I've got a 4 speed one (5th is there somewhere) that I'm not currently using. I assume you need one with the two holes in the bell housing for the speed and position sensors?
1 hour ago, jonnyony said:
Sorry, you are correct. I need the @260/5 for the M20. I'll correct the post now.
No worries.
Give Kayne Barrie a call and have a chat - 027 497 5330. He may have something suitable.
2 hours ago, jonnyony said:
Don't need the sensor holes as its running moronic 1.3. Cheers.
Freudian slip or typo?
