bumpstop325 0 Report post Posted February 26, 2006 (edited) This is my dyno run that happened on friday arvo. 135kw or 175hp at wheels. 375nm or 270 foot pounds. rolling road dyno and did A/F plot(blue line) the run was done in 3rd gear. the guy had trouble preventing the gearbox from kicking down and holding it, in that gear. Edited February 26, 2006 by bumpstop325 Quote Share this post Link to post Share on other sites
Guest Andrew Report post Posted February 26, 2006 lotsa torque - not a lot of power Quote Share this post Link to post Share on other sites
bumpstop325 0 Report post Posted February 26, 2006 just need talk. top speed was about 170km/h Quote Share this post Link to post Share on other sites
Grant 4 Report post Posted February 26, 2006 That is an impressive amount of torque. Power is what I would have expected. Cheers Grant Quote Share this post Link to post Share on other sites
conrod 1 Report post Posted February 26, 2006 That sounds about spot-on for a standard 3.5 litre (I assume it is?) Should go nicely. :thumb: Quote Share this post Link to post Share on other sites
cainchapman 0 Report post Posted February 26, 2006 Well done Tim. It pulls like a school-boy. Quote Share this post Link to post Share on other sites
bumpstop325 0 Report post Posted February 26, 2006 stock standard apart from headers. Cant use the factory one's (naturally) Quote Share this post Link to post Share on other sites
Guest Spargo Report post Posted February 26, 2006 Massive amount of torque. A Drag would be interesting :thumb: Quote Share this post Link to post Share on other sites
conrod 1 Report post Posted February 26, 2006 Pics please!!!!! I have always been a fan of this conversion, really good bang for your buck I reckon, and plenty of scope for future upgrades as well. :thumb: Quote Share this post Link to post Share on other sites
BM WORLD 1266 Report post Posted February 26, 2006 thats not bad , std e28 spec is 218hp at fly wheel and 310Nm . for the 10:1cr or 211hp and 305Nm for std e34 9:1cr Quote Share this post Link to post Share on other sites
E30-323ti 66 Report post Posted February 28, 2006 Torque seems too high. Is that corrected properly for the gear & diff ratio used?? At 100%VE it can not put out more than 350Nm, the newer BMW's put out just over their engine size in torque due to the Variable Valve timing & lift, let alone a SOHC M30. Quote Share this post Link to post Share on other sites
Gus 5 Report post Posted February 28, 2006 is the blue line the A/F ratio like other dynos? why is it all over the place? because of the automagic? Quote Share this post Link to post Share on other sites
westy 614 Report post Posted February 28, 2006 Is it just me,or is that a REAL flat torque curve. Nice work. Quote Share this post Link to post Share on other sites
Gus 5 Report post Posted February 28, 2006 Is it just me,or is that a REAL flat torque curve. Nice work. similar to m20 Quote Share this post Link to post Share on other sites
cainchapman 0 Report post Posted February 28, 2006 Torque! Quote Share this post Link to post Share on other sites
E30-323ti 66 Report post Posted February 28, 2006 All of those graph's show "torque at the wheels", this hasn't taken into account the gear/diff ratio/tyre slippage (if a rolling road) and if an auto the time the torque converter isn't locked up. For example my dyno plot shows a peak torque reading of 1348Nm. This was done in 4th (1:1) with a 3.46:1 diff ratio, so the actual engine torque is: 1348/3.46=~389Nm Then you can start arguing about drivetrain losses etc... till the cow's come home. Quote Share this post Link to post Share on other sites
Gus 5 Report post Posted February 28, 2006 asking the dyno guy at mine, he said there is no way of working it out properly. i imagine there is, he just being lazy....but was more showing for the curve comparison Quote Share this post Link to post Share on other sites
ED1RTY 2 Report post Posted February 28, 2006 One thing i dont get is that an old member on here (EVLM3 was his p plate, dunno bout his screen name) his car was 325m engine custom headers and exhaust and bored intake was pulling 223kw on a rolling road dyno, yet this is a 3.5 litre? Lost me..... Quote Share this post Link to post Share on other sites
Gus 5 Report post Posted February 28, 2006 223kW? i know the car...something wrong with the dyno reading. would have been in the 100kW region Quote Share this post Link to post Share on other sites
*sic 1 Report post Posted March 1, 2006 223?? hell no. Quote Share this post Link to post Share on other sites
bumpstop325 0 Report post Posted March 1, 2006 (edited) The car is in bits at the moment. will take pic's of the engine/gearbox when it is finshed being painted. The whole sub frame is out and i am currently sand blasting and painting the compents at the moment in hams. In my bat cave. Its was done in 3rd gear. no 'lock in' for the convetor. Edited March 1, 2006 by bumpstop325 Quote Share this post Link to post Share on other sites
kiwi535 538 Report post Posted March 1, 2006 for comparison purposes my m30 did 139 kw@5891rpm (which equates to 184km) hr at rear wheels(one of those kind that the dyno bolts directly to the wheel hubs )and the tourque was 275nm@4293 which is 135km hr in fourth.My car is stock except for a smaller rear muffler.Fourth is a 1 to 1 ratioMy A/f was a bit sketchy too.The revs scale stops at 6093....The readout is actually 187.4Hp SAE so i hope my conversion is right Quote Share this post Link to post Share on other sites
bumpstop325 0 Report post Posted March 8, 2006 motor plus header pic's Quote Share this post Link to post Share on other sites
Escada 0 Report post Posted March 23, 2006 The reason the torque figures are so high is because thats the roller reading, the torque has been multiplied by the gearbox. I've got a graph of my mr2 with 860nm if you wanna see it Quote Share this post Link to post Share on other sites
