darkblue44 3 Report post Posted December 14, 2017 I am planning to upgrade the shock absorbers on my2010 BMW M3. Should I go for Bilstein Shocks? Quote Share this post Link to post Share on other sites
Herbmiester 947 Report post Posted December 14, 2017 Look at Koni that way you can adjust the rebound to suit the spring rate. If the bilsteins suit your spring rate then they will be fine. Shocks in NZ can be pricy. Try Demon Tweeks in the UK even with shipping and GST they can be quite a bit cheaper. 1 Quote Share this post Link to post Share on other sites
gjm 3300 Report post Posted December 14, 2017 I'm much more a fan of Koni than of Bilstein, but Bilstein are very good too. OE used to be Sachs - don't know if they still are. What is the intended use? Koni produce a kit specifically aimed at road-going drivers who might do a trackday once in a while - the Koni/H&R trackday kit: p/n 1250-1004 Koni.H&R trackday kit.pdf 1 Quote Share this post Link to post Share on other sites
E30 325i Rag-Top 3043 Report post Posted January 11, 2018 If you want to upgrade the shocks then go the full hog and get KW, v3 or v4 fully adjustable. not cheap but worth it, especially if you want to "tune" your ride to suit your driving, ie, for daily v track v week-end trips. Quote Share this post Link to post Share on other sites
