WYZEUP 283 Report post Posted December 27, 2017 No longer required as were used to roll project car around. Set of four 15x7 et20 E34 Style 5s Only 3 centre caps. Fitted with 185/65/15 yokohama earth1 tyres - note tyres are down to the wear marks $200 Need to be picked up in hamilton or can drop off on the 10th jan between hamilton and wellington for a small fee Quote Share this post Link to post Share on other sites
WYZEUP 283 Report post Posted January 3, 2018 bump Quote Share this post Link to post Share on other sites
Rob HB1 90 Report post Posted January 4, 2018 Do you know if these centre caps will fit 4 stud 15x7 on e30? Quote Share this post Link to post Share on other sites
WYZEUP 283 Report post Posted January 4, 2018 I am unsure, I am heading back to hamilton tonight and have a friends with some 15” weaves so will test them and let you know Quote Share this post Link to post Share on other sites
WYZEUP 283 Report post Posted January 15, 2018 Bump $150, need them gone. pick up in hamilton Quote Share this post Link to post Share on other sites
Rob HB1 90 Report post Posted January 18, 2018 On 1/5/2018 at 7:27 AM, WYZEUP said: I am unsure, I am heading back to hamilton tonight and have a friends with some 15” weaves so will test them and let you know Did u get to test fit? Quote Share this post Link to post Share on other sites
WYZEUP 283 Report post Posted January 18, 2018 Sorry i ran out of time. from looking at realoem, the caps look way different. ill see what i can arrange Quote Share this post Link to post Share on other sites
WYZEUP 283 Report post Posted January 27, 2018 bump Quote Share this post Link to post Share on other sites
nick496 273 Report post Posted February 22, 2018 Right, so I ended up getting around to comparing these with e30 15in basketweaves. In short they don't fit. E30 waffle in Black. E34 waffle in silver. E30 waffle on E34 rim, larger than the hole E34 waffle on E30 rim, center bore of E34 waffle larger, and won't press in. See differences here: E30 on Left with twist to lock, E34 on Right with just a push in See difference in centre widths here Quote Share this post Link to post Share on other sites
