WYZEUP 283 Report post Posted January 8, 2018 Im on the hunt for a LSD centre for my 2.93 medium case diff, i have a spare diff so really only need the centre....time to upgrade so i dont keep smashing axles. Quote Share this post Link to post Share on other sites
BM WORLD 1298 Report post Posted January 8, 2018 just be careful as I think the 2.93 gears use a different lsd centre to the higher number diffs ,as the gears are different thickness etc I have a 3.91 lsd from a e34 medium case if that helps you Quote Share this post Link to post Share on other sites
WYZEUP 283 Report post Posted January 8, 2018 Yeah I have heard the lower ratios have a different centre to the higher ones. ill keep it in mind tho thanks Quote Share this post Link to post Share on other sites
FIAT 131R 223 Report post Posted January 9, 2018 Can do Wellington based. The LSD centres for the higher ratios have a different collar height. If you are interested call me on 021 449 242 Geoff Quote Share this post Link to post Share on other sites
