curryinahurry
Where to buy ZF Lifeguard 6?
Hi Team,
I've been wanting to get my trans serviced on the 335i for a while.  Done plenty of reading on the type of fluid, but theres no general consensus on the best alternative to the factory ZF LG-6 fluid.
So, the question is - does anyone know a good place to buy Lifeguard 6 fluid without bending over at the dealer???
Or a different fluid which had been used with proven success?
Thanks,
Andrew
have some options. ph details below
Talk to Transmission Solutions in Manukau and buy the Amtex 6 speed oil of them. It's what we used
BTW...you need to set the oil level in park on a level surface at 45 degrees C
Edited by B.M.W Ltd
  • Thanks 1
Make sure you replace the loom socket as well when you do this. They leak and can only be replaced with the pan off. These pans have a fit once or leak tolerance
Thanks Glenn - Do you normally replace the bolts as well?
No... plastic will fail before over tightening occurs
