Herbmiester 947 Report post Posted March 26, 2018 So my wifes 2011 Octavia had an issue with the clock spring/slip ring which is a pretty common fault on VAG vehicles using that platform. Anyway I replaced the clock sring but I cannot resent the fault codes using either my DCAN cable or my Bluetooth OBD2 device. I have used a few different programs including Torque which seems to read every other OBD2 car I have connected it to but no the Skoda. To be clear I can connect my OBD2 device but it can't make a connection with the car. Any thoughts? Quote Share this post Link to post Share on other sites
B.M.W Ltd 951 Report post Posted March 26, 2018 What you are using is probably not suitable to reset the module. Are you absolutely sure the fault was the clock spring or a ghost fault code ? Quote Share this post Link to post Share on other sites
Herbmiester 947 Report post Posted March 26, 2018 No not 100% sure it was the clock spring but the old clock spring did have an open circuit where the replacement does not. Also the problem does seem to be pretty widespread with a number of articles being written on the subject that exactly mirror the symptoms I have. My main issue is that I have lost a bit of faith in the VW Skoda dealer, I won't go into detail but every service requires a second visit. Quote Share this post Link to post Share on other sites
Olaf 3426 Report post Posted April 6, 2018 On 3/26/2018 at 4:02 PM, Herbmiester said: My main issue is that I have lost a bit of faith in the VW Skoda dealer, I won't go into detail but every service requires a second visit. most inconvenient. Quote Share this post Link to post Share on other sites
