NZ00Z3 190 Report post Posted April 22, 2018 Hi Car: E46 323Ci, manual, 160,000 km Problem: When changing gears, especially 1st to 2nd, the rev's hang at around 1,800 rpm for about a second then drop as they should. Work already done: replaced ICV and cleaned the throttle body Any suggestions on what to look at next? Regrads Murray Quote Share this post Link to post Share on other sites
kwhelan 243 Report post Posted April 22, 2018 checked throttle pedal and cable for sticking, return spring still tight Quote Share this post Link to post Share on other sites
NZ00Z3 190 Report post Posted April 23, 2018 22 hours ago, kwhelan said: checked throttle pedal and cable for sticking, return spring still tight Thanks, Checked them as suggested, only thing found was a lot of slop in the cable at idle. Adjusted it out and the problem seems to be fixed. 1 Quote Share this post Link to post Share on other sites
