modz 156 Report post Posted July 1, 2018 I've finally got my E46 330ci back on the road and now have the final electrical gremlins to resolve before I'm happy with it. I replaced: Steering wheel / airbag, seats (retaining the original tensioners and wiring), BMW business stereo has been removed and not yet replaced. All Pillar trims are removed for recovering. Issues: Airbag and seatbelt light on the dash Indicators and hazards work on outside but not on dash Stereo doesn't appear to have any power Passenger wing mirror stuck up Central lock doesn't work (not sure it did before tbh) I haven't yet checked the dash cluster for backlight when lights are on, or high beam etc; but the above + a quick google indicate a K BUS issue to me. Approach: I'm planning to unplug the battery, remove, check & replace all fuses, re attach battery before going further with the K-BUS. Is it worth getting my own Port Scanner to assist with codes? I've been looking at Bluetooth > iOS ones. Any other tips/tricks/suggestions appreciated Quote Share this post Link to post Share on other sites
NZ00Z3 190 Report post Posted July 1, 2018 You want a scanner that can talk to all the computers in the car, not just the engine DME, so the bluetooth> iOS ones will likely not be your best choice. Some people use the Foxwell 520 scanner. https://www.foxwelltech.com/product/item-340.html I use INPA on a windows 10 surface pro. Its cheap to set up and can talk to all computers https://www.bimmerforums.com/forum/showthread.php?2184573-The-Z3-Diagnostics-Thread-Instructions-Experiences-Discussions-Experimentation Others will likely chime in with there preferred scanners Quote Share this post Link to post Share on other sites
modz 156 Report post Posted July 2, 2018 Champion, thanks for the advise. That Z3 diagnostics page you linked makes for good reading. 2 hours ago, NZ00Z3 said: You want a scanner that can talk to all the computers in the car, not just the engine DME, so the bluetooth> iOS ones will likely not be your best choice. Some people use the Foxwell 520 scanner. https://www.foxwelltech.com/product/item-340.html I use INPA on a windows 10 surface pro. Its cheap to set up and can talk to all computers https://www.bimmerforums.com/forum/showthread.php?2184573-The-Z3-Diagnostics-Thread-Instructions-Experiences-Discussions-Experimentation Others will likely chime in with there preferred scanners Quote Share this post Link to post Share on other sites
modz 156 Report post Posted July 4, 2018 Ok so I pulled the battery off for 20 mins, and then pulled and tested each fuse while the battery was off. No blown fuses and everything in the correct location. Stereo does now have power, Instrument cluster has illumination, high beams and spotlights work So the problems I'm left with (I suspect not all related) No indicators/hazards/high beam don't show on dash Airbag & seatbelt light illuminated Central lock doesn't work Passenger mirror doesn't fold down I'll scanned it and clear codes before I do anything further, the battery has been in / out and flat in the last 6 months so no telling what is a red herring. Quote Share this post Link to post Share on other sites
modz 156 Report post Posted July 4, 2018 Side question, I have removed the Steering wheel controls from the steering wheel. Could this cause any related issues? Quote Share this post Link to post Share on other sites
M3AN 4145 Report post Posted July 4, 2018 The airbag and seatbelt lights will illuminate if the seats or belts are disconnected whilst the battery is connected. They need to be reset with the right equipment, I doubt they're related to your other problems. Quote Share this post Link to post Share on other sites
modz 156 Report post Posted July 4, 2018 Thanks M3AN, makes sense. Will get that out the way and pursue the other items 9 hours ago, M3AN said: The airbag and seatbelt lights will illuminate if the seats or belts are disconnected whilst the battery is connected. They need to be reset with the right equipment, I doubt they're related to your other problems. Quote Share this post Link to post Share on other sites
