FuManChu 2 Report post Posted October 27, 2018 Hopefully not a dumbass question, but my 03 M57d powered X5 has a non functioning AC,cooling condenser fan. I'm looking to replace it, but have only found "petrol" fans that have a fractionally different oem part number , but look identical on the realoem diagram. Logic says, how different can it be? Any experience with this? Quote Share this post Link to post Share on other sites
allan 295 Report post Posted October 28, 2018 HI no expereience with these but you are correct using bmw fans 03 x5 E53 3.0d June the part number comes up as 64546921382. Using the info button it was only used on the M57 and M57n 3.0d. The petrol one had 64546921381 as a part number but was used in the M54 3.0, M62 4.4 N62 M62 4.6is and N62 4.8is. Pelican parts has both listed as complete units only shroud, motor and fan cover around the $563 US mark. Would be using a meter and checking the circuit and other items as that looks like it could get expensive real quick. Quote Share this post Link to post Share on other sites
dirtydoogle 383 Report post Posted October 28, 2018 I know the v8had the pwm control fan, am unsure on the diesel (can have a look at mine if need be) Quote Share this post Link to post Share on other sites
_ethrty-Andy_ 2153 Report post Posted October 29, 2018 take no notice of what it looks like on the diagram, just a image they use for everything. plug the part number into google image search for more accurate pics might just be the resistor pack if it has one. try bypassing it and turn the AC on. Quote Share this post Link to post Share on other sites
