k3zza 3 Report post Posted November 21, 2018 Doing suspension on E36 328i coupe and need to get this hex bolt with washer for front strut to king pin. BMW will take 2 weeks to ship. M12x20 https://www.ecstuning.com/b-genuine-bmw-parts/hex-bolt-with-washer-priced-each/31311136465/ Can anyone help me out as one side suspension is already done. 1 Quote Share this post Link to post Share on other sites
zero 1162 Report post Posted November 22, 2018 Just go to the wreckers. Zebra or pick a part Quote Share this post Link to post Share on other sites
Mad_Max 236 Report post Posted November 22, 2018 3 minutes ago, zero said: Just go to the wreckers. Zebra or pick a part Will be the easiest option. Have got 2 sitting here if you can't find any locally. Local bolts suppliers (Blacks, EDL etc.) can also supply - just make sure grade 10.9 to match OEM specs. Quote Share this post Link to post Share on other sites
M3AN 4198 Report post Posted November 22, 2018 (edited) Just get them from a bolt shop, that's what I did when I needed longer ones to fit shims. Use medium loctite. Bolt Shop - Wairau Steelmasters - Penrose They're the ones I know, there will be many more. Easy. Edit: hard bolts either black or zinc plated. Edit, edit: have some used ones here in Ellerslie that you can have for free if you want... 4 of them. Edited November 22, 2018 by M3AN Quote Share this post Link to post Share on other sites
k3zza 3 Report post Posted November 22, 2018 Thanks Dave. New shocks all in and time to get WOF. Thanks for the help everyone. Quote Share this post Link to post Share on other sites
M3AN 4198 Report post Posted November 22, 2018 All good, glad to be able to help. Quote Share this post Link to post Share on other sites
