E30 325i Rag-Top 3034 Report post Posted January 31, 2019 Hmmm, I still think referring to something as a "haldex system" is a bit of a sweeping generalisation as there are now a variety of different systems, electronic, mechanical, electro-mechanical, FWD bias, RWD bias, etc all being shoe-horned in together under the same terminology. 1 Quote Share this post Link to post Share on other sites
BreakMyWindow 1965 Report post Posted January 31, 2019 2 hours ago, E30 325i Rag-Top said: Hmmm, I still think referring to something as a "haldex system" is a bit of a sweeping generalisation as there are now a variety of different systems, electronic, mechanical, electro-mechanical, FWD bias, RWD bias, etc all being shoe-horned in together under the same terminology. There’s been some great adoptions made from the Haldex idea too. The AYC in the mid 90’s onwards mitsu evo’s was one of my favs 1 Quote Share this post Link to post Share on other sites
E30 325i Rag-Top 3034 Report post Posted March 25, 2019 On 1/23/2019 at 10:38 AM, BlackrazorNZ said: My understanding is the new M-1xx's use a Haldex-like version of XDrive, where is full time FWD until it needs rear wheel traction. As opposed to the current implementation of XDrive on most cars, where it's a full time AWD system with a nominal 40/60 front/rear torque split, with the addition of an electronic multi-plate clutch and sensors that allow you to send up to 100% of torque to front, rear, or even 1 specific wheel. That's the advantage over the normal Quattro system Audi uses as the Quattro system will always apportion at least some torque to every wheel, even if they're slipping. Found some more info on the up-coming 1 Series xDrive. It reads very much like it is nearer to your description of the current xDrive systems currently used, with intelligent torque vectoring linked to the DSC. Hopefully it is a configurable setting in the M135i in the same way it is in the M5 driving modes. Quote Share this post Link to post Share on other sites
BlackrazorNZ 83 Report post Posted March 27, 2019 (edited) I will be very interested to see what eventuates, however I'm somewhat skeptical as the engine mounting in the new 1-series has been confirmed as transverse, where as the M5-esque implementation of Xdrive relies on a good old longitudinal mounted engine. Perhaps they've found some clever engineering way around it, but every transverse mount AWD implementation I've seen has been front bias with no more than 50% torque ever available to the rears. Edited March 27, 2019 by E30 325i Rag-Top quoting prev post Quote Share this post Link to post Share on other sites
E30 325i Rag-Top 3034 Report post Posted March 27, 2019 The info I saw definately mentioned 100% can be sent to the rear if / when required. My reference to the M5 was more that you can select which mode you want - RWD, AWD, Rear-bias AWD, etc. I would like to see this feature in the M135i, fingers crossed! 1 Quote Share this post Link to post Share on other sites
BlackrazorNZ 83 Report post Posted March 28, 2019 Have you got a link to the article? I'd be very interested to have a read Quote Share this post Link to post Share on other sites
BlackrazorNZ 83 Report post Posted March 29, 2019 Here's a vid of the new M135i - exhaust noise and track handling sample. Little bit of understeer but nothing too bad. Definitely saddened to see little/no rear end wiggle tho Quote Share this post Link to post Share on other sites
balancerider 830 Report post Posted March 29, 2019 @BlackrazorNZ it looks rapid but pretty homogenous c.f. the other German marques hot hatches (A45 / Golf R). At least the RS3 still has the 2.5T 5cyl in it for now. Seems the Germans all want to emulate each other as much as possible (A3 sedan / CLA class / 2 series Gran Coupe) and now this. A bit of individuality wouldn't go amiss... Quote Share this post Link to post Share on other sites
