jasera94 30 Report post Posted February 11, 2019 Hi Team, I am on the hunt for power steering Banjo Bolts for an E30 M16x28 and M14X1,5X26 with washers. Appreciate any help to source these locally.Thanks 1 Quote Share this post Link to post Share on other sites
aja540i 1925 Report post Posted February 11, 2019 Trade parts 151 Wairau rd, North shore 1 Quote Share this post Link to post Share on other sites
C-130 Hercules 572 Report post Posted February 11, 2019 You might have luck at zebra Onehunga. They have a white e30 there but I am not sure if the rack is still in. 1 Quote Share this post Link to post Share on other sites
M3AN 4194 Report post Posted February 11, 2019 (edited) And remember they're crush washers, you need 4 for rack side and 4 for the pump side, one for either side of the hose fitting. And BMW NZ charges over $3 each... ridiculous. Edit: may only need 2 crush washers for the pump side, depends how the feed line attaches. Edited February 12, 2019 by M3AN 2 Quote Share this post Link to post Share on other sites
jasera94 30 Report post Posted February 22, 2019 Thanks for all the recommendations! I ended up buying them from Fcpeuro along with a bunch of other things I needed, however, they did not have the washers for the M16 bolt. Thinking - would a rubber washer from supercheap/repco work better/the same as a crush washer? otherwise will fork out the $3 per washer from BMW NZ :( 1 Quote Share this post Link to post Share on other sites
M3AN 4194 Report post Posted February 22, 2019 They're exactly $3.06+GST each from BMW NZ, I just picked some up. You can't use a rubber washer, no. As it turns out I have 2 new spares - 32411093597 (A16X22-CUSN) that I don't need if you want to buy them off me (at cost - $7) instead of BMW. I can show you the BMW invoice, I'm in Ellerslie. Quote Share this post Link to post Share on other sites
