Guest Ari Gold
S42 badassness
Guest Spargo
agaiThe S42 came in different versions, here is some data on the 8/1995 evolution.
Bore / Stroke: 86,5mm / 85mm
Displacement: 1998ccm
Compression ratio:12.4
Rod length: 145mm
Intake cam degree / spread: 312 / 94
Exhaust cam degree / spread: 304 / 98
Intake valve diameter: 35mm
Exhaust valve diameter: 35mm
Intake dimensions: 52mm wide / 29.7mm height / 14.85mm radius
Slide throttle diameter: 46mm
Carbon airbox
Exhaust manifold: 4-2
Engine management: ecu4a.1
Performance: (DIN 70020)
285hp at 8300rpm
245nm at 7000rpm
max rpm: 8500rpm
Petrol quality: Super plus ROZ 98
hotness, that in the e90 320?
Looks familiar
Edited by bravomikewhiskey
An interesting evolution from the early Touring cars we've got.
The last of the Diet Coke cars were this spec, isn't that what Dennis has? Only made them for one year like this, was designed in a big rush by Mclaren instead of BMW Motorsport, but really effective.Quite radical compared with earlier versions. Edited by conrod
zip tie badass
hey they hold my car together good
No, ours are 94/95 cars. Maybe Bruce Miles' one is this spec. It wasn't racing at Skope this year.
Scott O'Donnell's is the sister car to our 2.
Different plumbing at the front, doesn't have the bracing at the front of the motor, nor the shock setup. Inlet manifold has minor differences too.
Ours have Pi systems in them and that ECU looks about the same size, but to my knowledge don't have the same cover.
They look more like this one.
thats some serious bracing of the front end.....
what are the two alloy pipes with the blue valve right at the front?
Edited by kiwi535
water pipes to the two front radiators, and the blue cap is an air bleed.
For shore!!! Zip tie's are my best friend aswell.
Those engines are tits. Is the front of these cars built as a space frame sort of style?
