F10er 66 Report post Posted February 15, 2021 (edited) You could try updating the CIC software with winkfp. What ever you do, don't try updating it a kdcan cable. You have to use an ICOM A with a most interface ICOM B Edited February 15, 2021 by F10er Quote Share this post Link to post Share on other sites
The Bimmer 12 Report post Posted February 18, 2021 When I changed the radio frequency. Usually I used the manipulation profile or expert mode in ncs expert. .After write the the CAS and FRM and I just change the job to sg_codieren and change ecu to cic or ccc and ctune. and done. no issues. Dont use the default profile and some cases car needs to complete sleep or need power reset or use tool32 to restart your I drive. Quote Share this post Link to post Share on other sites
jdm bm 1 Report post Posted March 3, 2021 Still banging my head on this one and no one in the uk seems to be able to do it 😪 Quote Share this post Link to post Share on other sites
KwS 2448 Report post Posted March 12, 2021 I recently followed the first post in this thread to the letter and coded my car (E63 with CCC) from JDM to Euro frequency and reception is fine. Apparently its the same as coding CIC, maybe see if there is an option in this thread you didnt code? Quote Share this post Link to post Share on other sites
Alexis_c17 0 Report post Posted November 24, 2021 (edited) Same problem here. I have change my vo and coding my car but i have a poor reception on my Japan car e93 2008 with a cic. Do you have find a solution? Edited November 24, 2021 by Alexis_c17 Quote Share this post Link to post Share on other sites
The Bimmer 12 Report post Posted December 1, 2021 try to use or add 825 in the VO and re encode. Quote Share this post Link to post Share on other sites
MrA4Awesome 0 Report post Posted December 29, 2024 On 5/11/2019 at 8:01 PM, sobanoodle said: You need to do some coding. HU_(cic/nbt/entry) RADIO_COUNTRY => ECE FM_DEEMPHASIS => 50us AF_FUNKTION => af_ein Thank you @sobanoodle Just did this 30mins ago with a Nexus Nexlink and BimmerCode in expert mode on my F20 116i Sport. Piece of cake - worked like a charm. Quote Share this post Link to post Share on other sites
