Herbmiester 947 Report post Posted June 10, 2019 Ok guys I am seriuosly considering manually converting my new e36 323i to manual. I have a g220 from a 4cyl so will need a 6cyl flywheel and clutch. What are the options, dual mass singles mass, what size? The M52 b25 will likely stay stock and I have a 3.46 diff ratio so might have to change that. Quote Share this post Link to post Share on other sites
KwS 2448 Report post Posted June 10, 2019 Iirc the common single mass conversion flywheel is an M20 one? I recall that's what was used when my 323i was converted. I believe there are good options for flywheel and clutch kits on trademe now, but someone else will need to chime in on that. 1 Quote Share this post Link to post Share on other sites
Mad_Max 236 Report post Posted June 13, 2019 Yes I believe the M20 is the common "semi performance" upgrade. You can get away with the M4X SMF and clutch as well, they can slip a little at high revs or when being pushed hard but I got away with one behind my "slightly modified" M52B28 for a year or so - not ideal but will work. And there are places around that can rebuild the M4X clutch to have more clamping force than a stock M5X one. 1 Quote Share this post Link to post Share on other sites
