xtr041947
Battery Charger for F10 M5
Hi Guys,
I have an M5 (F10) 2012, my stop start feature doesn’t seems to work. A common suggestion on google search suggests charging the battery. Could anyone recommend the best charger to use on my car?
Thanks in advance.
The stop-start won’t run if the engine is cold or there is high electrical drain (aircon on etc), but often suggests a battery on the way out (or disabled by previous owner) if it never works.
CTek chargers have a good reputation
There are around 25 criteria for the car to meet before it will turn off but low battery charge is one of them. Most people are thankful it doesn't work so embrace it haha
Stop start in an M5, be glad it’s not working.
A decent battery charger that can charge different battery types (AGM/Calcium/Lead) should be able to keep it topped up.
