bravo
e30 FL brake duct LHS
I need the brake cooling duct and the plastic skirt it fits into at the wheel end - LHS on my FL e30.
Graeme McC - I got one off you before - you don't hapen to have another lying around??
Edited by bravomikewhiskey
I've been through this so a tip for you when you get one is to rivet the plastic duct to the front valance so you don't lose another one.
good idea - got a spare one by any chance? I need the skirt it fits into too as once the duct was gone it flapped in the breeze and wore against the tyre.
My low wheel offset meant my tyre rubbed against the flap when at full lock so when I got a replacement duct I riveted it as far forward up the brake intake port on the valance as possible then with what was left of my plastic flappy guard (hard to find a replacement for this) I cable tied to the duct so that it pulled it forward out of the wheel's way. I suggest you do the same if your panel is rooted.
Edited by Carl
