Simcox_325i 0 Report post Posted April 1, 2006 anyone know why my Fuel Consumption Gauge is sticking. any quick fixes?? Quote Share this post Link to post Share on other sites
bravo 35 Report post Posted April 2, 2006 who cares? it's a gimmick and dubious to it's accuracy in any case. Probably just getting on. Pull the instrument cluster apart and check for carbon build up on that needles track but otherwise it's probably just done it's dash. escuse the pun. Quote Share this post Link to post Share on other sites
Carl 3 Report post Posted April 2, 2006 who cares? it's a gimmick and dubious to it's accuracy in any case. Probably just getting on. Pull the instrument cluster apart and check for carbon build up on that needles track but otherwise it's probably just done it's dash. escuse the pun. My fuel useage meter is quite accurate, I wouldn't call it a gimmick by any means. Quote Share this post Link to post Share on other sites
bravo 35 Report post Posted April 2, 2006 (edited) how do you know? Unless you sit at a constant value on the gauge for a set number of kms and then check the gas used. Otherwise its all in your head - the needle is constantly moving as terrrain and road conditions vary - at the end of a trip you may average fuel consumption somewhere in the range you saw the needle hovering but that's the point - its rough, rough good enough, but not accurate by any means. Vacuum gauges for fuel usage are indicative only. sorry. Edited April 2, 2006 by bravomikewhiskey Quote Share this post Link to post Share on other sites
Carl 3 Report post Posted April 2, 2006 how do you know? Unless you sit at a constant value on the gauge for a set number of kms and then check the gas used. Otherwise its all in your head - the needle is constantly moving as terrrain and road conditions vary - at the end of a trip you may average fuel consumption somewhere in the range you saw the needle hovering but that's the point - its rough, rough good enough, but not accurate by any means. Vacuum gauges for fuel usage are indicative only. sorry. Dah, of course the needle is going to constantly move, who's fuel usage is constant???Averaging is the only way to calculate mpg and as far as averages concern mine is very accurate and it is quite sensitive too as it makes for a wee bit of fun tailgating buses and trucks to get the highest mpg reading as possible from the draft. Also, where does it say it's vacuum related? Quote Share this post Link to post Share on other sites
*sic 1 Report post Posted April 2, 2006 not accurate. no point. Quote Share this post Link to post Share on other sites
Carl 3 Report post Posted April 2, 2006 How do you know it's not accurate, can you proove it doesn't work? Quote Share this post Link to post Share on other sites
DCEIVN 0 Report post Posted April 3, 2006 accurate or not.... it only tells you your consumption at that very point of time so if youre a pussy you can use it to optimise your driving (gear choice etc) at that very point in time according to the conditions. But theres no way I'd be using it to calculate the average fuel consumption just from the readings on the gauge. If it was accurate it would be moving VERY quick back and forth. Quote Share this post Link to post Share on other sites
Carl 3 Report post Posted April 3, 2006 Use it how you like. It's just another gismo to give me something to play with while I drive. I hate cruising on a trip with it below 11k/l ~ 9l/100k so adjust speed accordingly especially with the fuel prices as they are. Quote Share this post Link to post Share on other sites
gmccormack 0 Report post Posted April 3, 2006 Vacuum gauges for fuel usage are indicative only. sorry. It's not a vacuum gauge, it is sent a signal directly from the ECU. Its one of the wires on the three pin plug of the ECU. You may want to check that plug first.Replacing the gauge would be your next move. I've have plenty of spares if you want to give it a try. Quote Share this post Link to post Share on other sites
Simcox_325i 0 Report post Posted April 3, 2006 cheers for that gmccormsck Quote Share this post Link to post Share on other sites
Carl 3 Report post Posted April 3, 2006 Yes, thanks Graeme for coming through with the knowledge yet again, I didn't think they were vacuum gauges but wasn't sure. Quote Share this post Link to post Share on other sites
