mavericg 1 Report post Posted January 16, 2020 (edited) Hi there, any thoughts on possible issues when steering do a slight pulsing vibration /movement to left or right on the moment you hit a full stop and your stepping the break pedal or auto hold is engaged? Been noticing this issue only when on stop but once I drive it disappears. No vibration when braking while moving though and no error codes. Any thoughts what to look for? Inspected the engine bay and the power steering reservoir has some liquid/oil sweat on top of it. Not sure if it's related though or a possible sign of a problem somewhere? Car is an 08 X5 3.0si Edited January 16, 2020 by mavericg Quote Share this post Link to post Share on other sites
Jacko 2237 Report post Posted January 16, 2020 Brake rotors warped or unevenly warn, sometimes even pad build up on the rotors can accumulate unevenly. Quote Share this post Link to post Share on other sites
qube 3571 Report post Posted January 16, 2020 most likely warped rotors, need replacement Quote Share this post Link to post Share on other sites
KwS 2448 Report post Posted January 17, 2020 Sounds like the OP is meaning it pulses when the car is stationary? Does it have active steering? 1 Quote Share this post Link to post Share on other sites
Jacko 2237 Report post Posted January 17, 2020 I cant read. Quote Share this post Link to post Share on other sites
