wmkar 2 Report post Posted January 23, 2020 Hi folks, I own a 1992 525i (E34) Touring for 27 years. Recently it has been leaking a lot of oil from the rear self-leveling suspension. Can anyone recommend a good, honest, good priced place to get it fixed cause I am on a tight budget and can't go to a dealer! I also have a rear trunk door lock that no longer works would love to get that fixed too. I am based on the North Shore in Auckland. Thanks heaps and look forward to your advice and replies 1 Quote Share this post Link to post Share on other sites
aja540i 1925 Report post Posted January 23, 2020 Try Bavarian motors, on the shore and the owner had / has one of these as a daily. Note, fixing the SLS will be expensive, most people end up swapping it for standard struts and springs. 3 Quote Share this post Link to post Share on other sites
wmkar 2 Report post Posted January 23, 2020 5 hours ago, aja540i said: Try Bavarian motors, on the shore and the owner had / has one of these as a daily. Note, fixing the SLS will be expensive, most people end up swapping it for standard struts and springs. Thanks your for advice Andrew! I've been to Ernst and his team at Bavarian before! Going to bring my car in next week! I think Ernst's has replaced his suspension on his own suspension to standard struts - might be a good long term option cause its been giving me lots of trouble! 1 Quote Share this post Link to post Share on other sites
wmkar 2 Report post Posted April 6, 2020 Refer to my post January 23... Can anybody recommend me where to get my trunk door lock fixed...it doesn’t function by itself, I have to use the car key to open it every time...... thanks in advance Quote Share this post Link to post Share on other sites
Olaf 3426 Report post Posted April 6, 2020 (edited) I have little direct e34 experience, so take this with a grain of salt, and investigate widely. Many BMWs have (common) locking issues - eg e46 door locks... you revert to key operation, and then the barrel craps out as they're not designed to be worked by key all the time. e36 touring, e46 touring, e39 touring, e60 sedan boot... all suffer from wiring issues between body and tailgate or boot lid, leading to the symptoms you mention. I'd suggest a BMW specialist to resolve your e34 touring woes; someone who knows where to look and how to resolve, will save you time. You'll want to get this done soon, lest your lock barrel malfuntions too. Some of the Auckland crew should be along shortly to recommend! Hope that helps. Edited April 6, 2020 by Olaf Quote Share this post Link to post Share on other sites
