Bimmerfreak 0 Report post Posted February 10, 2020 If anyone can please help me... i had Adaptive headlight faults then it also started showing the right indicator fault, day time running lights, etc. I thought it was because of some moisture in headlights so i ordered control modules for both lights. All changed to new modules and used sealant to seal the lights properly which is good now in terms of moisture. But the warnings are still there and specially the indicator fault is not good at all since i need warrant as well. Can anyone help me please, i am based in Auckland. Thanks in advance for any advice or help Quote Share this post Link to post Share on other sites
qube 3571 Report post Posted February 10, 2020 could be battery or could be the comfort access module going crazy and throwing codes for other things. dont spend money fixing random things, get it scanned and properly diagnosed and fix it once fix it right Quote Share this post Link to post Share on other sites
E30 325i Rag-Top 3034 Report post Posted February 10, 2020 Did you get the codes cleared? Not sure these ones just clear themselves when issue is fixed. Quote Share this post Link to post Share on other sites
promo 93 Report post Posted February 11, 2020 Hi, The f series adaptive module needs to coded. I have done these before. and its a common issue for water ingress which damages the module. Quote Share this post Link to post Share on other sites
