Jacko 2390 Report post Posted March 6, 2020 After a B40 23 spine wheel nut key ASAP, anyone got one? p/n 36136762344 https://www.ecstuning.com/b-genuine-bmw-parts/wheel-bolt-adapter-code-40/36136762344/ Quote Share this post Link to post Share on other sites
Mad_Max 236 Report post Posted March 6, 2020 Got codes 38 and 39, and 3 unidentified...... if you have no luck, let me know asap as will be going out to stored cars over the weekend and can go through them too. Worst case if you're stuck and need it done straight away, use a double hex socket, smash it over the outside. Just make sure it's a tight fit (can check what size I've used before, it's an imperial one). Has worked for me every time. 1 Quote Share this post Link to post Share on other sites
Gaz 1077 Report post Posted March 6, 2020 Head into the local dealer in the morning 1 Quote Share this post Link to post Share on other sites
