zero 1162 Report post Posted March 6, 2020 Hi guys I'm replacing the steering column on my e46 daily as the old one is damaged. I've swapped everything over from my old one so far except for the ignition barrel. I managed to get my good ignition barrel out using my key and a bit of wire. But I cant get the barrel out of the replacement steering column as there is no key for it. How to remove ignition barrel with no key? It doesnt matter if it gets damaged, as the barrel is being replaced with my existing one anyway. Can anyone advise? Quote Share this post Link to post Share on other sites
B.M.W Ltd 951 Report post Posted March 6, 2020 Swap over the lock housings Quote Share this post Link to post Share on other sites
BM WORLD 1293 Report post Posted March 6, 2020 as above or drill it out carefully , bit by bit without damaging the housing Quote Share this post Link to post Share on other sites
zero 1162 Report post Posted March 7, 2020 8 hours ago, BM WORLD said: as above or drill it out carefully , bit by bit without damaging the housing What size drill bit do you recommend? Quote Share this post Link to post Share on other sites
zero 1162 Report post Posted March 7, 2020 I managed to drill it out and install my ignition barrel. Thanks for the help guys. I couldnt swap the housings over as the housing was damaged Quote Share this post Link to post Share on other sites
