topnotchrally 176 Report post Posted March 20, 2020 (edited) Made by Bosel. Will bolt on to E39 Sedan, can be modified to fit Touring.50mm ballBolts on to factory points. Much stronger than crappy 'aftermarket' fitted towbars which are kludged to fit.More than $500 new (not installed) Yours for $150 If you want to fit it to a Touring, in picture 2, the hole you see without a bolt in it is the hole for mounting on a touring. You need to have a nut welded to the underside of that hole. You also need to have a bit of steel plate welded to the top bar to extend it to reach beyond that same hole. (and drill a hole in it to match the lower hole) Edited March 28, 2020 by topnotchrally Quote Share this post Link to post Share on other sites
BreakMyWindow 1987 Report post Posted March 21, 2020 Hey could you please update your original post with the asking price? Quote Share this post Link to post Share on other sites
topnotchrally 176 Report post Posted March 21, 2020 4 minutes ago, BreakMyWindow said: Hey could you please update your original post with the asking price? Sorry, my oversight. Fixed now. 1 Quote Share this post Link to post Share on other sites
topnotchrally 176 Report post Posted March 28, 2020 Added description of how to modify it to fit a Touring. Quote Share this post Link to post Share on other sites
Young Thrash Driver 1021 Report post Posted March 28, 2020 Does it fit any particular rear bumper, or all of them? Quote Share this post Link to post Share on other sites
topnotchrally 176 Report post Posted March 28, 2020 3 minutes ago, Young Thrash Driver said: Does it fit any particular rear bumper, or all of them? I can't say for sure but I can tell you that you have to make some cuts in the bumper to allow it to fit. I have pictures and measurements of the cuts that need to be made, from the car I took it off of. I can post them if you would like. Quote Share this post Link to post Share on other sites
