Secniv 182 Report post Posted March 30, 2020 I have 3 BMWs so I ‘need’ a scanner right! Given the E30 and E36 are OBDI and the E60 is OBDII I needed a scanner that will cover both. I looked at finding an old laptop with serial port and setting up DIS etc but I prefer to just diagnose and wrench so went with plug n play. Enter the Foxwell NT530 plus serial adapter. Look at overseas but with shipping/GST price diff was negligible ($385+$65 for adapter) and I’m glad I did. Brought off BAT Tech Automotive and Greg has been really helpful getting me up and going. There was a delay with the adapter has it had to come out of China but he lent me one so I could start using sooner. Greg gave me some instructions for scanning OBDI and have only used on the E36 so far. GUIDE 1. plug the tool into the OBD diagnostic socket. 2. turn the ignition on [all lights show in the instrument cluster including engine and other warning lights] 3. start the engine [this wakes up the ECU’s] 4. if unable to start the engine, then ensure that an appropriate battery charger is connected effectively, and all chassis grounds are functional [i.e., it is earthed properly] ... jump start batteries are not necessarily as good as a means of voltage conditioning; as you must ensure the best voltages remain available during testing. This ensures that all modules are awake and functional and able to report. 5. once you start the testing please continue and do not interrupt the process Please note: if any ECU module has a fault in the system, then it may not communicate or report any PID [data stream]. Faults in ECU’s DO NOT necessarily clear if they are still faulty. In cases where the vehicle is also OBD2 compliant it is important to check for the communications with OBD2 data stream The E30 / E36 are biased toward OBD1 .... some E36 that have both types of OBD plugs may have data available from each plug [this is quite rare but cannot be overlooked]. So far I have been able to - reset airbag light (after swapping to later style wheel) - diagnose a fault with the oxygen sensor cyl1-3 (according to Fedex it’ll turn up today!) - the front brake pad sensor was unplugged so already paying for itself. Next I’ll actually read the manual and see if I can reset the oil service light and check the performance of the individual control modules. 1 Quote Share this post Link to post Share on other sites
NZ00Z3 190 Report post Posted March 30, 2020 I too have purchased a Foxwell NT530 with BMW software. I find it excellent to use and really like that it talks OBD1. 1 Quote Share this post Link to post Share on other sites
Secniv 182 Report post Posted March 30, 2020 1 hour ago, NZ00Z3 said: I too have purchased a Foxwell NT530 with BMW software. I find it excellent to use and really like that it talks OBD1. Have you been able to figure out how to reset oil service? Found some instructions re NT520 but doesn’t seem to apply to NT530 (OBDI anyway). Quote Share this post Link to post Share on other sites
NZ00Z3 190 Report post Posted March 30, 2020 Haven't needed to do that yet, so haven't looked. Quote Share this post Link to post Share on other sites
hotwire 352 Report post Posted March 31, 2020 I have the NT644 & confirmed it will not reset the service schedule (inspection anyway) on analogue system in the E30 but does read codes & show current data. It shows as having done reset but doesn't action. That said, nor does the much more elaborate Autel tablet scanner at work. I need to use the older Hanatech work scanner to do so. 1 Quote Share this post Link to post Share on other sites
Secniv 182 Report post Posted March 31, 2020 8 hours ago, hotwire said: I have the NT644 & confirmed it will not reset the service schedule (inspection anyway) on analogue system in the E30 but does read codes & show current data. It shows as having done reset but doesn't action. That said, nor does the much more elaborate Autel tablet scanner at work. I need to use the older Hanatech work scanner to do so. Guess I’ll have to stick to just crossing 7&19 Quote Share this post Link to post Share on other sites
B.M.W Ltd 951 Report post Posted March 31, 2020 (edited) After lock down I could sell you the OBD1 reset tool Which resets Service, ABS, SRS. On the left is the other early E30 D plug type, service only. $150 for both or $100 for the OBD1 & $50 for the early tool Edit: The OBD1 tool resets every OBD1 fitted models not just E30 & E36 Edited April 1, 2020 by B.M.W Ltd Quote Share this post Link to post Share on other sites
treone 680 Report post Posted April 2, 2020 On 4/1/2020 at 9:22 AM, B.M.W Ltd said: After lock down I could sell you the OBD1 reset tool Which resets Service, ABS, SRS. On the left is the other early E30 D plug type, service only. $150 for both or $100 for the OBD1 & $50 for the early tool Edit: The OBD1 tool resets every OBD1 fitted models not just E30 & E36 I would be interested in the OBD1 tool if your offer is not taken up. Cheers Quote Share this post Link to post Share on other sites
Secniv 182 Report post Posted April 2, 2020 On 4/1/2020 at 9:22 AM, B.M.W Ltd said: After lock down I could sell you the OBD1 reset tool Which resets Service, ABS, SRS. On the left is the other early E30 D plug type, service only. $150 for both or $100 for the OBD1 & $50 for the early tool Edit: The OBD1 tool resets every OBD1 fitted models not just E30 & E36 I’ll pass thanks anyway Quote Share this post Link to post Share on other sites
