bumpstop325 0 Report post Posted April 12, 2006 From r3vlimited. This will be useful for anyone, who is not too sue where they can jack their car up from and safely place axle stands under. Quote Share this post Link to post Share on other sites
smokenbaby 0 Report post Posted April 12, 2006 Little bit hard to position the jack under the pictured jacking points with the car on it's side. DON'T TRY THIS AT HOME KIDS. Quote Share this post Link to post Share on other sites
Carl 3 Report post Posted April 12, 2006 Using the floor jack on the chassis rails to lift the front of my car has caused my rails to get slightly bent, i'd advise that this may not be a good idea...everything else is spot on IMO Quote Share this post Link to post Share on other sites
Guest Andrew Report post Posted April 13, 2006 Using the floor jack on the chassis rails to lift the front of my car has caused my rails to get slightly bent, i'd advise that this may not be a good idea...everything else is spot on IMO your joking? heh chassis rails aren't meant to "bend"It's easily the strongest point on the bottom of the car along with all the subframes. Quote Share this post Link to post Share on other sites
ED1RTY 2 Report post Posted April 13, 2006 (edited) Andrew, you are too right, if your chassis rail is bent doesnt that affect WOF Requirments? Diff I find is best for trolley jack, otherwise i have to use a scissor jack, car is to low for standard jack... Edited April 13, 2006 by sakdbma Quote Share this post Link to post Share on other sites
Carl 3 Report post Posted April 13, 2006 Andrew, you are too right, if your chassis rail is bent doesnt that affect WOF Requirments? Diff I find is best for trolley jack, otherwise i have to use a scissor jack, car is to low for standard jack... That's what I was told, if the chassis rail is too bent then it'll fail a WOF, mine have bent up so i've started to jack the bugger up from the control arm bushes instead which is slightly easier as sometimes depending on the surface the jack won't fit under the rails. Quote Share this post Link to post Share on other sites
