nz320i
Outer rear CV removal
need to fix or replace the lot, the boot on the inner CV has been split for about 2 months :o and i get a noise from that side of the car all the time and im guessing ill replace the lot, how an earth do i take it out? the inner has 6 allen key bolts, but cant work out the outer, do you undo the huge bolt in the middle of the disc?? cheers, also new boots from the dealer?
Can you just replace the whole half shaft, surely there must be loads of them around, dime a dozen
yeah but how do you separate the half shaft from the disc??
You need to remove the large nut inside the hub. The nut is secured by a special lockwasher which you need to remove first to get the nut loose, or you will not get the socket onto the nut.
Leave the wheel on and on the ground when removing the nut as the handbrake will not hold the hub securely enough by itself to allow you to crack the nut loose.
