Craig B 0 Report post Posted September 20, 2020 Have a 2009 320i e90 wagon Not long after getting this I (well the wife was actually driving) blew a top radiator hose, so ordered a new one from Silverdale Radiators, this in hindsight was a mistake as it leaked from day one, oh and obviously I cracked the inlet connector on the radiator trying to get the old hose off, great. Stupidly put some radiator stop leak in it, and seemed to fix the crack, but the new hose just didn't seal properly, so ended up topping up coolant every 3 months or so, until the replaced hose failed catastrophically on a drive home, fortunately only 2 mins from home so got there safe. Replaced the top hose again and surprise surprise, no leaks, no refreshing coolant. Life was good for a while. Then a couple of weeks ago developed a coolant smell in the aircon, shortly followed by steam puffing from the bonnet at the lights, figured it was the cracked radiator, so replaced that, change over went well, but still had same problem, coolant smell in cabin, steam puffing out at intersections (got some pretty funny looks). Radiator inlet hose was very hot, outlet hose cold, loosing coolant from the belly-pan when stationary, radiator fan not running. Googled the bejesus out of it and eventually determined mines a 4 cylinder so mechanical water pump, (yah... finally a postie for having the 4 cylinder) Read lots about cracked head gaskets, broken cooling fans, and that I should get warnings or go into limp mode if coolant system fails, well, none of that, just puffing steam and smell. Replace the thermostat, which was not too bad to do in place without removing the pump, just need the right torx socket with a swivelly extension, oh and re-insulated the thermostat wiring which is pretty close to the engine so had melted... Bled system, Started up on stands and what do you know the outlet warmed up and the fan started all by itself, magic. Took for a run, slight coolant smell, but this was just the excess coolant purging itself. Lesson: Don't buy the cheapest parts, DON'T use radiator stop leak, avoid the american youtube videos if you've got a 320i, they mainly seem to have 6 Cylinders Quote Share this post Link to post Share on other sites
zero 1162 Report post Posted September 21, 2020 What coolant combo are you using? Your engine shouldnt be overheating and blowing cooling system parts. Quote Share this post Link to post Share on other sites
Jacko 2371 Report post Posted September 21, 2020 You forgot key part of lesson, dont buy 4 pot bmws 1 1 Quote Share this post Link to post Share on other sites
F10er 66 Report post Posted September 21, 2020 N46 = 2nd worst engine ever made by BMW. 1st place goes to N63 twin turbo. Quote Share this post Link to post Share on other sites
Eagle 1787 Report post Posted September 21, 2020 11 hours ago, Craig B said: Lesson: Don't buy the cheapest parts, DON'T use radiator stop leak, avoid the american youtube videos if you've got a 320i, they mainly seem to have 6 Cylinders To be fair anyone with a clue would of told you that 1 Quote Share this post Link to post Share on other sites
