BM WORLD
BMW 6 speed manual gearbox
BMW 6 speeed manual gearbox getrag from a e46 M3 s54 (the best box)
will bolt up to m54 m52 m50 m44 m43 m42 m40 type engines as well
have 6 speed box gearlever parts new, either to suit a e46 or e36(may work in a e30 as well)
etc gearbox crossmember from a e46 m3
manual driveshaft m3
flywheel and clutch set up
gearlever leather boot, foam pad and rubber boot 6speed gearknob
manual brake pedal
may have some clutch metal and rubber line parts
021433600
$3950
Hey mate, will this bolt up onto an e39 525i touring? Any additional bits and pieces needed?
Also looking at long term project plans to either supercharge engine or drop in new engine so hopeing this gearbox conversion can take it.
Thanks
Thanks
yes bolts , yes you will need more bits
and its gone now
