curryinahurry 39 Report post Posted January 28, 2021 Hi Team, My elderly neighbour came around the other day asking for some help on his 2002 525i E39. Hes got a yellow ABS light, Traction Control Triangle (ASC) and a check engine light on. He tells me that the ABS light goes off after ~30 minutes of driving. I gave it a scan on INPA and it looks like his car has a vacuum leak that's causing the CEL. So the CEL is probably a separate issue. However, I'm not sure what's causing the ABS and Traction Control light to come on as I cant connect to the ABS/Traction control module. I was wonder if a faulty ABS module would cause this? I heard failures on the flexible PCB within the ABS unit is quite common. Are they any other tests I can do to diagnose the problem? Thanks, Andrew Quote Share this post Link to post Share on other sites
dirtydoogle 383 Report post Posted January 28, 2021 Scan it with something that will talk to it. Otherwise there is a plethora of things that will cause an ABS fault You can test the sensors with a DMM with diode function Quote Share this post Link to post Share on other sites
curryinahurry 39 Report post Posted January 29, 2021 2 hours ago, dirtydoogle said: Scan it with something that will talk to it. Otherwise there is a plethora of things that will cause an ABS fault You can test the sensors with a DMM with diode function Thanks Doug - by sensors you're referring to the wheel speed sensors? Quote Share this post Link to post Share on other sites
dirtydoogle 383 Report post Posted January 29, 2021 Yes, there are a few guides online to diagnosing them Quote Share this post Link to post Share on other sites
NZ00Z3 190 Report post Posted January 31, 2021 Do you have pins 7 and 8 on the OBD2 connector shorted? You need this to talk to modules other than the DME and EGS. Quote Share this post Link to post Share on other sites
