aja540i 1909 Report post Posted February 7, 2021 the GM in my e39 touring appears to kaput, soft close on the tailgate not working, no auto up/down on drivers window, etc, question is, are the GMs specific to wagon or sedan, or can I recode a sedan unit to work in the wagon? I have tried a sedan unit and it is not plug and play, still does some wierd stuff, but I don't want to go through the hassle of coding it if it still won't work. Quote Share this post Link to post Share on other sites
Eagle 1773 Report post Posted February 8, 2021 I dont see why not provided they are both the same OBC type and similar vintage(maybe backward compatible on that one like LCM's) Did you test the capacitors when you had the old one apart. Ive fixed a couple by replacing them. Quote Share this post Link to post Share on other sites
aja540i 1909 Report post Posted February 8, 2021 No, I haven't dived in that deeply yet, I have managed to find one with identical part number on ebay, so will try that first. If it doesn't work I will do some more investigationing. Quote Share this post Link to post Share on other sites
BreakMyWindow 1963 Report post Posted February 9, 2021 afaik they are plug and play but do need programming to suit the particular car, I have the software to do that if needed. Quote Share this post Link to post Share on other sites
aja540i 1909 Report post Posted February 20, 2021 On 2/10/2021 at 8:41 AM, BreakMyWindow said: afaik they are plug and play but do need programming to suit the particular car, I have the software to do that if needed. Can you do it in a pre OBD car? Quote Share this post Link to post Share on other sites
BreakMyWindow 1963 Report post Posted February 20, 2021 2 hours ago, aja540i said: Can you do it in a pre OBD car? As in via the round plug connector in the engine bay? If so yep. Quote Share this post Link to post Share on other sites
