Deffed
M60b40 upgrades
Any information on maximum hp on standard bottom end m60b40 v8,im looking for this information for performance parts requisition, cams and throttle bodies.
  • Like 1
Stock internals will take up to 13psi before you need to start looking at aftermarket pistons. 13psi proboably equates to around 500-600hp.
There are four different intake manifolds - you want the earliest one with the trumpets.
For throttlebody use the one from the n62b48, its 3mm bigger than the biggest m62 one. You will need to port match the intake manifold to it but thats easy
Thanks for the info,im planing to run itb,dose the information include this type of induction,8x65hp throttle bodies = 550hp 65 hp per cylinder.
Itbs make a great noise, but a very low bang for the buck, and can actually lose power if done wrong. Unless you have a set of s62 itb's lying around, or money is no object, I wouldn't recommend it.
If money is no object these are good;
https://racehead.com.au/product/bmw_m60_m62_v8_complete_itb_kit_open_trumpetpet/
Biggest gains you can get on this engine is good headers, and bigger cams. Neither is cheap
Edited by zero
  • Like 1
Il will be getting cams and headers made.
