SmackJackTheCrackerMan 54 Report post Posted April 23, 2021 (edited) Could anybody clarify the torque numbers for the suspension arms etc? I have found so many different specs on old forums and YouTube videos with varying numbers of “correct” torque. Edited April 23, 2021 by SmackJackTheCrackerMan Quote Share this post Link to post Share on other sites
smiddy 76 Report post Posted April 23, 2021 Did this couple weeks back, great mod!! Was varying torque figures, just used long spanners and breaker bar with 1/2 inch drive and did things up tight. Be sure to go straight to alignment and not to far away if you are DIYing. Quote Share this post Link to post Share on other sites
SmackJackTheCrackerMan 54 Report post Posted April 24, 2021 3 hours ago, smiddy said: Did this couple weeks back, great mod!! Was varying torque figures, just used long spanners and breaker bar with 1/2 inch drive and did things up tight. Be sure to go straight to alignment and not to far away if you are DIYing. Yeah I’ve just finished installing coilovers front and back and the M3 arm up front. None of the wheels are now facing forward 🤦♂️ Just called the alignment shop and they’ve already closed. I’ll have to wait till next weekend now. 🤞🏼 Quote Share this post Link to post Share on other sites
M3AN 4111 Report post Posted April 24, 2021 Is it one of these? 3AZ wishbone to front axle support E81, E87, E90, E91, E92, E93 - M12 8.8 Replace nut Tighten under normal load Torque 68 Nm Tightening angle 90 A E81, E87, E90 / RWD, E91 / RWD, E92 / RWD, E93 - M12 10.9 Replace nut Tighten under normal load Torque 100 Nm Tightening angle 90 A 4AZ wishbone to pivot bearing E81, E87, E90 / RWD, E91 / RWD, E92 / RWD, E93 - M14 Replace nut 165 nm E90 / AWD, E91 / AWD, E92 / AWD - M14 Replace nut 80 Nm 1 Quote Share this post Link to post Share on other sites
