hayleyt 0 Report post Posted November 6, 2021 Hi there, I just got my 2008 135i imported from Japan, wanting to change the nav and radio, I just bought the activation code and map download from Navi expert but it didn’t work as they only have the USB version of the premium nz/aus maps. Apparently mine can only be updated through DVD. Does anyone have the link to a DVD update version for premium maps? Quote Share this post Link to post Share on other sites
Blackie 510 Report post Posted November 8, 2021 Can you not create an .ISO file from the USB and then burn it to a DVD? Maybe drop @promo a PM. He is an expert on these things I believe. Quote Share this post Link to post Share on other sites
F10er 66 Report post Posted November 9, 2021 On 11/7/2021 at 9:25 AM, hayleyt said: Hi there, I just got my 2008 135i imported from Japan, wanting to change the nav and radio, I just bought the activation code and map download from Navi expert but it didn’t work as they only have the USB version of the premium nz/aus maps. Apparently mine can only be updated through DVD. Does anyone have the link to a DVD update version for premium maps? Not as easy as that unfortunately. An 08 would probably still be CCC in which case you need to change all the navigation hardware in the car and recode the headunit. Not really worth doing that as the last nav update for CCC was 2014 from memory. If it's CIC i think the HDD needs to be changed to euro spec then the headunit will need to be coded and maps loaded on to the HDD. Quote Share this post Link to post Share on other sites
The Bimmer 12 Report post Posted November 11, 2021 you need to add HIP Module in your CCC, Flash your CCC with ECE Firmware and need to remove your GPS cable from your Navigation HDD unit and plug to HIP module and reroute to Roof Aerial. Latest Update for CCC is 2014.For Maps FSC Activation Code I can generate Activation code for CIC, NBT headunits(Motion,Premiun,Next) for NZ new cars only and not retrofitted units and not Japan Quote Share this post Link to post Share on other sites
