Vass
E46 Bits & Bobs
Have various bits collected over the years that someone might find more use for. I've kept most as spares but don't mind clearing a bit of space either. Shoot a message for whatever you need. Would prefer local pickup (Halswell, Christchurch) but happy to post if I manage to find suitable packaging.
More photos: https://www.dropbox.com/sh/yt7zfmkdrysih7x/AAB_g7gtd1TopykigBSSmjgDa?dl=0
AUX adapter cable - $10
(Check if your headunit is compatible - https://e46radio.com/e46-radio-cd-tape-md-aux/)
Brake booster - $50
ABS unit - $100
Front bumper foglights - $20
Came off a non-msport facelift sedan, not sure what other models they'll fit.
Radiator top hose - $10
Dated 2017.
Centre console compartment for HVAC unit - $20
Suits a double-din setup, holds an HVAC unit snug as opposed to a sunglass compartment. Bottom clips broken but should still sit securely against the gearshift surround.
HVAC unit - $20
LCM - $40
Auto trans thermostat (unused) - $30
Final stage resistor - $20
Clock spring - $50
Blower motor - $50
Wiper linkage & motor - $100
Space saver spare wheel - $20
Air vents, switches, bumper shocks/mounts, hood & boot struts - $5 a pop
Edited by Vass
Are the electric mirrors electric fold in type?
I believe so. Came off a parts car. The driver's side one did fold in and operated fine, on the passenger door I later discovered the whole mirror control unit was missing so the mirror wasn't plugged in.
A bunch of this stuff and more are still available. Also about to rip into another partout project, a green 2002 320i e46. Will do a proper garage cleanup over Christmas and will be updating the post as parts start to come off. Feel free to message for any E46 bits you might be after.
292773583_2023-12-1718_00_06.thumb.jpg.e86229b6e05fd4df96f8136d0ef29c6c.jpg 1142034616_2023-12-1717_59_54.thumb.jpg.625f0a0b43fbf7d011998b27958e19dc.jpg
30 minutes ago, Chanderpaul said:
Hey,  is the aircon fan blow resistor still available?
Yeah should have a couple spares.
Sweet.  Cant believe how easily they die and during a f*cking heat wave.  How much for one shipped to Blenheim?
Shouldn't be much, I'll package it up and get a quote tomorrow. Will send you a PM
