Cammsport 391 Report post Posted April 9, 2022 Hi all, wondering if anyone had any tips or pointers as to my next move. Car historically has been fine with no issues. Didn't drive it (isolation for a week) and now it cranks but won't start. INPA isn't finding any fault codes. Battery voltage is ~13v. Crank or cam position sensor? Thanks for any suggestions/help! Quote Share this post Link to post Share on other sites
Cammsport 391 Report post Posted April 9, 2022 Also, does anyone know the duty cycle of these starters? Quote Share this post Link to post Share on other sites
Cammsport 391 Report post Posted April 9, 2022 Has spark and I can hear fuel pump prime when triggered by INPA. Fuel pressure at the rail. Quote Share this post Link to post Share on other sites
Twistee 496 Report post Posted April 9, 2022 Recheck your fuel pump / filter, it should absolutely fountain out of the fuel line when priming. I have been caught out assuming that a running pump and some fuel coming when priming means the pump is all good. Quote Share this post Link to post Share on other sites
Twistee 496 Report post Posted April 9, 2022 (edited) When you check the fuel pressure in INPA does it hold or drop off once primed ? Some good reading for the diagnostic walkthrough https://www.bimmerfest.com/threads/e90-n52-crank-but-no-start-issue.1402751/ Good luck. Edited April 9, 2022 by Twistee 1 1 Quote Share this post Link to post Share on other sites
Cammsport 391 Report post Posted April 9, 2022 Thanks heaps for that @Twistee! This is exactly what I'm after. I'll start working through it. 1 Quote Share this post Link to post Share on other sites
Cammsport 391 Report post Posted April 9, 2022 Interesting development. With fuel pump activated via INPA, engine *almost* started. I'm in with a sniff now. Quote Share this post Link to post Share on other sites
Twistee 496 Report post Posted April 9, 2022 That's great news, fingers crossed. Quote Share this post Link to post Share on other sites
Cammsport 391 Report post Posted April 9, 2022 And it starts! Although hesitant. Turned it off and starts fine now. Unsure as to what would have cause it but I want to nail it before the family gets stuck somewhere. I'll have a look a what relays fire the pump and see if they may have been getting sticky after sitting for 1 week. Or perhaps a tired fuel pump? Thanks heaps @Twistee, I was running pretty low on patience at the time. Also a HUGE thanks to @M3AN for taking the time to show me how to use INPA the other day. Long live the forums. 20220409_212121.mp4 2 Quote Share this post Link to post Share on other sites
M3AN 4104 Report post Posted April 9, 2022 Great result. 👍 Just be sure the easy start you got wasn't a result of residual pressure, you need to give it some time to depressurise before trying it again. Quote Share this post Link to post Share on other sites
