martyyyn 102 Report post Posted June 9, 2022 I'm about to buy a 120Ah i3 to do a 50km roundtrip commute with the odd 180km round trip. Are there any i3 owners on here or anyone with experience of charges at home ? Obviously the daily trip is easily doable on the standard 3-pin cable. We have a 15A plug in the garage to power a caravan I use as an office. That should be all we need shouldn't it ? Quote Share this post Link to post Share on other sites
E30 325i Rag-Top 3043 Report post Posted June 10, 2022 I know plenty of i3 drivers that have only used the 3-pin plug charger to keep the car topped-up. Can easy cope with the daily commute, you probably could miss a day and still re-charge to full overnight. Obviously take a bit longer for the 180km trip but should still be ok. 15A circuit will be great, just make sure the charger is in plenty of air / not in direct sunlight when doing the bigger charge as it has a thermal overload trip in it. 1 Quote Share this post Link to post Share on other sites
martyyyn 102 Report post Posted June 10, 2022 Thanks Jon Quote Share this post Link to post Share on other sites
Breaker 980 Report post Posted June 10, 2022 I’ve run my 60ah on 3pin 10a for last 2 years running up to 100ks a day, zero issues and wouldn’t install anything bigger for the i3, plenty of time overnight for a full recharge Quote Share this post Link to post Share on other sites
