godmars_snakly311 19 Report post Posted July 24, 2022 Hello all Does anyone knows any good company to make the coating services of the car and how much around in Auckland ? Cheers Quote Share this post Link to post Share on other sites
Twistee 501 Report post Posted July 24, 2022 Hi, Guessing you are after ceramic coating? If so you could try https://www.ocdetailing.co.nz/ who have a good reputation on here. There are plenty of others, prices a highly dependent on the current state, size, and desired finish of the car. As such prices are not typically outlined online other than starting from figures. Best of luck and hopefully you will post up your experiences if you go through with it. Quote Share this post Link to post Share on other sites
Neal 569 Report post Posted July 26, 2022 On 7/24/2022 at 9:21 PM, Twistee said: Hi, Guessing you are after ceramic coating? If so you could try https://www.ocdetailing.co.nz/ who have a good reputation on here. There are plenty of others, prices a highly dependent on the current state, size, and desired finish of the car. As such prices are not typically outlined online other than starting from figures. Best of luck and hopefully you will post up your experiences if you go through with it. And check out the e46 M3 that they have if you go there. Very nice build over the years of ownership 🙂 Quote Share this post Link to post Share on other sites
