Cement 912 Report post Posted August 22, 2022 Does anybody have an E46 with front sway bar like the one pictured below (in terms of shape, doesn't matter what brand or size) ... assume all 6 cylinders use this style ?. The one that was in my 318 goes straight across between the frame rail mounts so I can't use it as a reference for what I need in my car with the swapped engine.. I'd love to know the offset of the long section below the engine from where it goes through the mounts at the frame rails. Also if its straight down below the mounts or if its biased towards the front / back of the car. Mucho thanks !!! Quote Share this post Link to post Share on other sites
Eagle 1773 Report post Posted August 26, 2022 Can have a look tomorrow if you haven't got it sorted already 1 Quote Share this post Link to post Share on other sites
Cement 912 Report post Posted August 26, 2022 4 hours ago, Eagle said: Can have a look tomorrow if you haven't got it sorted already That would be great thanks I think from what i can see in the pic (if its similar) mostly what i need to know is how forward of the steering rack it is ... it looks kinda the same height but the fore / aft position is more interesting for my fitment 👍 Quote Share this post Link to post Share on other sites
Eagle 1773 Report post Posted August 28, 2022 Yeah bar comes straight down as is pretty much level with the base of the rack (lines sit about 1 inch lower). Approx 115mm from front rounded edge in center of rack to rear of sway bar Quote Share this post Link to post Share on other sites
Cement 912 Report post Posted August 28, 2022 14 hours ago, Eagle said: Yeah bar comes straight down as is pretty much level with the base of the rack (lines sit about 1 inch lower). Approx 115mm from front rounded edge in center of rack to rear of sway bar Perfecto thankyou very much for this !!! 👍 Now to see if anybody has a crappy old one so i can cut it up as a template ! Quote Share this post Link to post Share on other sites
