elias 460 Report post Posted December 1, 2022 Long shot but does anyone have any apex EC-7 wheels in e82 1 series fitment they'd consider selling? Fitting a big brake kit to my 135i and need them, in order to clear the brakes, only wheels ive found definitive info on so far regarding clearing 380mm 4 piston brakes. Cheers. Quote Share this post Link to post Share on other sites
Bandit 197 Report post Posted December 1, 2022 ARC8 from Apex will clear also. Here is a willing seller for you. Two sets available in 18 and 19 inches. BestGun will cheerfully measure up for you I'm sure. https://www.trademe.co.nz/a/search?member_listing=688807&bof=PBy7PxqY 1 Quote Share this post Link to post Share on other sites
elias 460 Report post Posted December 1, 2022 19 minutes ago, Bandit said: ARC8 from Apex will clear also. Here is a willing seller for you. Two sets available in 18 and 19 inches. BestGun will cheerfully measure up for you I'm sure. https://www.trademe.co.nz/a/search?member_listing=688807&bof=PBy7PxqY thanks for the lead, unfortunately those offsets do not work well at all on a 135i, Id need 18x8.5 et45 and from my research ARC-8 only clear 380mm brakes with a spacer, so would lower the offset even further. Appreciate the response, cheers Quote Share this post Link to post Share on other sites
akapjay 55 Report post Posted December 1, 2022 I am not the seller, but these are saved in my wishlist right now.. Help save me from myself. https://www.facebook.com/marketplace/item/475588381123677 APEX flow-formed ARC8 in hyper black (shadow chrome). 1) 18x8.5” ET38 2) 18x9.5” ET35 Perfect for E46 M3, E9x 335 and M3, Z4, and 135i (?) and possibly others. Mint and absolutely as new. $4000 new, sell $3,200. --- These are advertised as E82 friendly by Apex directly, spacer free. Front & Rear: 18x8.5" ET35 or ET38 with 235/40-18 tires Requires at least -2 degrees of front camber. Rear fender roll and/or negative camber may be required. 245/35-18 tires can fit with additional front negative camber. Rear: 18x9.5" ET35 with 255/35-18 tires Requires rear fender roll and pull. Requires rear negative camber to prevent rubbing. Brake Kits Known To Clear Brake Kits Known Not To Clear Stock 135i M-Sport Brakes Brembo/Dinan 6-Piston 355mm Brembo 6-Piston 355mm Brembo 6-Piston 380mm StopTech ST-60 6-Piston This table applies ONLY to 18x8.5" ET35/38 and ET45 ARC-8 and EC-7 designs. https://support.apexraceparts.com/hc/en-us/articles/360001541993-E8x-1-Series-Wheel-Tire-Fitment-Guide Quote Share this post Link to post Share on other sites
akapjay 55 Report post Posted December 1, 2022 ^ oh bugger, just re-read you're running 380mm brakes. Sorry m8! Quote Share this post Link to post Share on other sites
