hawk188 11 Report post Posted April 30, 2023 Greetings all - new and learning very simple coding using E-sys and managed to change JAP to NZ for radio (happy) 1st time. Can someone please let me know the codes to change using E-sys for : 1.Enable USB video play 2.Enable DVD in motion 3. Also, can the F20 be coded to enable Daytime driving lights ? If so where would I be looking? Thanks in advance !! Quote Share this post Link to post Share on other sites
Kodachrome 172 Report post Posted April 30, 2023 7 hours ago, hawk188 said: Greetings all - new and learning very simple coding using E-sys and managed to change JAP to NZ for radio (happy) 1st time. Can someone please let me know the codes to change using E-sys for : 1.Enable USB video play 2.Enable DVD in motion 3. Also, can the F20 be coded to enable Daytime driving lights ? If so where would I be looking? Thanks in advance !! Hi, Im a step behind you but wouldnt mind figuring those out too. However I cannot find a (free) working combo of E-Sys and any sort of launcher for it. What exactly did you use to get to this point? thanks! Quote Share this post Link to post Share on other sites
hawk188 11 Report post Posted April 30, 2023 7 hours ago, Kodachrome said: Hi, Im a step behind you but wouldnt mind figuring those out too. However I cannot find a (free) working combo of E-Sys and any sort of launcher for it. What exactly did you use to get to this point? thanks! Unfortunately E-sys launcher developer gone underground and no working copy ( not even paid ones as tokens have expiry dates). Only Premium E-SYS works. Don't think i am allow to put links or files here but I am sure you'll find it. Below is what i use and sure you'll find the same . It requires REARM script and reset of your computer date to workaround the token expiry. Hope this helps. 1.ESysLauncherPremiumSetup_2.8.2_Build_155 2.v63.3.003_PSdZData_Lite 3.E-Sys_Setup-3.28.1 Build 46869 4.E-Sys Launcher Premium Rearm 2.0.4 1 Quote Share this post Link to post Share on other sites
hawk188 11 Report post Posted May 1, 2023 Anyone ? Quote Share this post Link to post Share on other sites
promo 93 Report post Posted May 1, 2023 Hi, I do alot of FDL, FA coding as well NAV conversion. If you're based in Wellington i can do for you. The tools and various software I have are paid license versions.not free or cracked. 1 Quote Share this post Link to post Share on other sites
hawk188 11 Report post Posted May 1, 2023 4 hours ago, promo said: Hi, I do alot of FDL, FA coding as well NAV conversion. If you're based in Wellington i can do for you. The tools and various software I have are paid license versions.not free or cracked. Cheers for your reply promo ! I'm in AKL unfortunately and I'm only wanting to learn and 'tinker' just to keep me mind active Truly appreciate your offer .... thanks heaps anyway ! Quote Share this post Link to post Share on other sites
Kodachrome 172 Report post Posted May 1, 2023 (edited) 7 hours ago, promo said: Hi, I do alot of FDL, FA coding as well NAV conversion. If you're based in Wellington i can do for you. The tools and various software I have are paid license versions.not free or cracked. Thanks to Hawk188 I got an Esys version up and running, however having to set the data with a Admin level script to get ESys Premium launcher working takes my machine off the Web (as Google etc pick it up as a hacked pc). I have a yellow E-Net cable, but I cannot test if this setup is even working. This would be fine if I was doing it on my own car in my garden, but I was just trying to help out friend.. getting a bit OTT with all the hoops and BS the launcher guys put in place. @promo, what do you charge to do a radio region recode on a BMW F20 (2012 116i)? Edited May 1, 2023 by Kodachrome Quote Share this post Link to post Share on other sites
leexyj 0 Report post Posted August 23, 2023 hi @promo Hey Mate, I currently own a bmw 7 series f01 2009, and due to some water damage i had to swap the tv module and the HSR active steering module to used ones. I am quite strapped and was recommended you by the people of the forum for coding in Wellington. I was wondering if you could do something like that. cheers Quote Share this post Link to post Share on other sites
promo 93 Report post Posted August 27, 2023 On 8/23/2023 at 7:31 PM, leexyj said: hi @promo Hey Mate, I currently own a bmw 7 series f01 2009, and due to some water damage i had to swap the tv module and the HSR active steering module to used ones. I am quite strapped and was recommended you by the people of the forum for coding in Wellington. I was wondering if you could do something like that. cheers All sorted now. Leexyj found my number Quote Share this post Link to post Share on other sites
Khimo 0 Report post Posted February 27 @promo Hello good day I've recently purchased and imported a 2017 bmw 330e from Japan VIN: WBABE120X0K478175 Can you please help me update from id4 to id6, so i could be able to access Apple Car Play Quote Share this post Link to post Share on other sites
