nath 184 Report post Posted October 1, 2023 (edited) I see that I didn't make a post about the end result. 1998 B3 3.2 switch-tronic saloon manual 6 speed conversion. The 4 saloons which were built in RHD were all switch-tronic so I thought why not. Except for the steering wheel, everything is oem spec 3.2 manual. Sam at Hellbm completed the conversion for me, with my supplied parts including various new bushes, bearings etc: -M3 evo 420g, C.V driveshaft etc -New e36 m3 clutch, dual mass flywheel etc -New Alpina shift knob Sam completed the work smoothly and quickly which was awesome. In my tarting up of the driveshaft paint I had painted over the white alignment dots, and there was a bit of a thumpa thumpa at 90kmh which I attributed to this. Dots found, realigned and still thumpa. I took it apart again and lubed the splines up, checked preload on CSB etc. reassembled and vibration mostly gone. Maybe anything remaining is the rear wheel balance?? Clutch engagement was near the floor. Clutch pedal disassembled and found to have flogged out bushes/material which I rebushed and for the small amount of slack which was removed, the clutch engagement improved drastically. Darned plastic pedal... Alpina used the US spec Siemens MS41.1 which is half OBD2 and half OBD. INPA etc over usb identified EWS, KMB and ABS but would only access EWS for me to change from auto to manual. So I just removed the trans fault bulb from the cluster. No issues anyway with idle or rev hang, as evidently the Alpina DME don't have auto or manual allocation. I'm sort of curious whether the KMB fuels differently when pulling away from standstill between auto and manual, because I do have to focus a bit more than I recall on manual BMWs I have owned in the past. I still have the switchtronic steering wheel and will likely keep it out of sheer laziness, unless I can source an Alpina stitched airbag and have a sport wheel restitched to match... End result I'm really happy with. Edited October 1, 2023 by nath 10 Quote Share this post Link to post Share on other sites
Eagle 1788 Report post Posted October 3, 2023 Minor shimmys and resonance\humming are the only real issue ive ever had with BMW's. The ones that were smooth were ones that hadn't been touched from the factory. They may get a final balance as a complete assembly. TIS usually states for various BMW's that the driveshaft ends should be marked in relation to transmission and diff flanges due to this, obviously you cant do that with used parts though. Worn driveshaft center sleeve can cause vibrations, i usually replace it the same time as the flex disc. Assume you checked the CV joint. Also had crappy CSB's cause issues too. Quote Share this post Link to post Share on other sites
nath 184 Report post Posted October 3, 2023 1 hour ago, Eagle said: Minor shimmys and resonance\humming are the only real issue ive ever had with BMW's. The ones that were smooth were ones that hadn't been touched from the factory. They may get a final balance as a complete assembly. TIS usually states for various BMW's that the driveshaft ends should be marked in relation to transmission and diff flanges due to this, obviously you cant do that with used parts though. Worn driveshaft center sleeve can cause vibrations, i usually replace it the same time as the flex disc. Assume you checked the CV joint. Also had crappy CSB's cause issues too. Yeah- I'm not being overly pedantic but sort of expected that things would be more smooth. I do have a new flex disc and CSB+housing, but didn't fit them as the existing ones were in top condition. I have certainly had bad csb in the past on e30 and on a urS4 and the thumpa thumpa is very obvious! Quote Share this post Link to post Share on other sites
Eagle 1788 Report post Posted October 3, 2023 Yeah suppose it depends on how bad it is\can you live with it. Could have the balanced checked on the shaft just to be sure Have had some success rotating the position of the flanges but only if had to take the thing for another reasons. I usually tighten it up the the diff first and loosen the transmission cross member and mounts when car is level, push it up and down so everything rests in its natural position, then retighten. Quote Share this post Link to post Share on other sites
Sammo 2616 Report post Posted October 4, 2023 A special car just got a little more special! 1 Quote Share this post Link to post Share on other sites
