marcofreeman 0 Report post Posted May 6, 2024 Hello, The 2000 z3 has a WOF error due to the airbag light coming on for no apparent reason. Does anyone know what the cause is or can refer anyone to a diagnosis? Thank. Quote Share this post Link to post Share on other sites
Eagle 1778 Report post Posted May 6, 2024 Need to scan to determine what is it. Typically the passenger occupancy sensor mat fault or seatbelt pre-tenioner wire\plug loose. Worst case\less likely a module fault. Most workshops should be able to scan it for you Quote Share this post Link to post Share on other sites
NZ00Z3 190 Report post Posted May 6, 2024 If you want to get a scanner so you can scan it yourself, you'll need one with BMW software. Quote Share this post Link to post Share on other sites
BM WORLD 1295 Report post Posted May 6, 2024 check the impact speed sensor for water damage corrsion ,under the left seat under the carpet 1 Quote Share this post Link to post Share on other sites
