Cement 913 Report post Posted September 20, 2024 I got a hold of the floating hat bobbins today from https://braketechnz.com/ and measured them all up. They are very consistent and look to be of great quality. Made the final design tweaks (Dave from Brake Tech NZ recommended aiming for 0.2mm float on a street car) so I'm happy the bracket and hats are now ready to be made. Not quite sure when I'll be pulling the trigger on that just yet 😬 2 Quote Share this post Link to post Share on other sites
Cement 913 Report post Posted September 23, 2024 Got the vinyl cut stickers today and popped the rear ones on. They look pretty good, probably could have gone a little lower but job done all the same ... got some spares cut so I can move them next time if that ever comes around. 3 Quote Share this post Link to post Share on other sites
Harper 615 Report post Posted September 23, 2024 Where did you get the vinyl stickers? I'll need a set for when I do my calipers as well. Quote Share this post Link to post Share on other sites
Cement 913 Report post Posted September 23, 2024 1 hour ago, Harper said: Where did you get the vinyl stickers? I'll need a set for when I do my calipers as well. I used these folks on K Road: https://www.makeshop.co.nz and was $42 for the 8 I got cut. Supplied my own DXF artwork so they didn't have to mess about too much. DXF attached 👍 Brembo Logos.DXF 1 Quote Share this post Link to post Share on other sites
Cement 913 Report post Posted October 2, 2024 I got my brake lines, supplied locally via https://nz.helperformance.com/ ... if you're in need of tasty braided lines I recommend 👍 Last week also got the misc items from Spareto (front caliper pin kit, basic pads and M3 parking brake shoes). Have yet to pull the trigger on the custom brackets and hats due to cost ... hopefully will order on pay day 😬 Then only need to arrange the remaining cross over pipe for rear caliper I stuffed up. 3 Quote Share this post Link to post Share on other sites
Neil McCauley 483 Report post Posted October 2, 2024 Hel are awesome to deal with! Got some F30 Brembo to E90 braided lines off them which they actually stock off the shelf. 1 Quote Share this post Link to post Share on other sites
Cement 913 Report post Posted October 3, 2024 15 hours ago, Neil McCauley said: Hel are awesome to deal with! Got some F30 Brembo to E90 braided lines off them which they actually stock off the shelf. Yea when I spoke to the chap and I mentioned that an off-shore vendor had the particular lines to match my caliper swap situation and he was able to look it up on some Hel database for the 'recipe' essentially and manufacture off that 👍 Pretty sweet they share their knowledge like that internally. Quote Share this post Link to post Share on other sites
Cement 913 Report post Posted October 19, 2024 Received the rotors ahead of schedule which was a nice surprise !! The hats and brackets are ordered and being produced, should be here in a couple of weeks ... then I only need fluid to get everything assembled up Quote Share this post Link to post Share on other sites
Cement 913 Report post Posted November 13, 2024 Have been at the mercy of UPS India since the 25th of October when they got a hold of my brackets and hats from Protolabs !! Absolute sh*t show, with nothing but what I suspect are 'fake news' scans and updates (requesting more info from sender) while they sand bag and prioritise planes loaded full of plastic nonsense from Temu Anyhoooo it seems the parts have left at last and ETA is Friday but I'll believe that when I see it. In other news I got the fancy NAS fasteners I needed out of Australia (ones supplied with the bobbins were too short), have ordered 20x cobalt drills which were $1 each on clearance from Paykels (!!!) and the rear discs are at the engineers getting the retaining screw holes moved. Quote Share this post Link to post Share on other sites
Cement 913 Report post Posted November 17, 2024 So I got the aluminium hats on Friday as promised about ten minutes before having to leave for a weekend away. The brackets are still hung up with UPS locally for some obscure reason, which I need to sort on Monday. The hats look really good and fit up nicely Also had time to get one of the rear corners assembled ... the brackets did not centre the caliper spot on so I have spaced it over using some washers for now. Just need to adjust the parking brake and wire up the pad wear sensor and that corner is complete (bar bleeding). Fitted up with the too short bolts temporarily while I wait for the drills to finish up the proper fasteners. 3 Quote Share this post Link to post Share on other sites
Cement 913 Report post Posted November 19, 2024 The front caliper brackets finally arrived, look great ... definitely won't be breaking any time soon !! On the down side, fairly heavy as expected. Completed the drilling of the front rotor hat bolts ... lucky I got the drills for $1 each as I was only brave enough to use each drill for two holes. It was pretty sketchy and slow going but got there in the end with 'only' three broken drills and written off bolts. Quote Share this post Link to post Share on other sites
Cement 913 Report post Posted November 20, 2024 Got the rears finished up tonight and made a start on the front right corner ... the fit is absolutely bang on which I'm pretty happy about !! Nice when all of the design and validation pays off. I'll validate the front left fitment is also good then get ready to paint the front calipers yellow. First time I've actually done a side by side of the rotors ... left is the 330 size at ⌀325x25 and right is the new ⌀356x30 3 Quote Share this post Link to post Share on other sites
Cement 913 Report post Posted November 25, 2024 I had a play with my wire tying pliers ... this is just to prevent the locking nuts coming off completely in the event they loosen ... it's not the full blown lock wire style used on blind bolts. Started rubbing down the front calipers ready for paint ... not sure how the yellow will cover over red 🤔 Might be worth hitting them with some grey primer first even though i could go straight over the top hmm. Quote Share this post Link to post Share on other sites
Cement 913 Report post Posted November 28, 2024 Got the front calipers painted, baked and decals applied ... only to find the Textar anti rattle spring ordered is the wrong size Located the (hopefully) correct one which is on the way from Spareto now. Just in case anybody else stumbles across this looking for the correct part, this is what I have ordered and should be correct: https://spareto.com/products/delphi-accessory-kit-disc-brake-pads/lx0469 I already hate the retention pin system, potentially as I have new pins and have put an extra layer of paint in the holes I'm trying to whack them in to ... but still, just seems pretty suck. Forgot to mention previously also I swapped the bridging pipes end for end as the Renault mounts the caliper to the front of the car and the E46 to the rear. 3 Quote Share this post Link to post Share on other sites
Cement 913 Report post Posted December 6, 2024 (edited) Got everything assembled and bled after getting the correct retaining springs ... have ordered some retrofit pins also which take a R clip instead of having to be smashed in. Hopefully they arrive soon and ahead of (re)certification. Got out for a drive to bed everything in, feels pretty good ... would like a firmer initial pedal so will likely do the M3 master cylinder swap at some point. Edited December 7, 2024 by Cement 5 Quote Share this post Link to post Share on other sites
Cement 913 Report post Posted February 4 I decided to go the whole hog and change out the master cylinder to better suit the new setup. The new item is from a M3 with MK60 ABS pump which has a 25.4mm front and 22.2mm rear bore. Side benefit of the later model master is the ports for pressure sensors, will integrate them into my custom electronics for monitoring at some point. The swap out will change the (calculated) front bias from 63.4% to 60.5% and should firm up the pedal feel. It's all completed now and the brakes certainly have a very solid feel so pretty happy with the result for sure and was well worth the effort, seat of the pants test suggests braking performance is improved but could be related to how solid it feels. Now for the story in pictures ... first up was the booster and master sourced from Ebay / https://mpartsworldwide.com/ at a pretty reasonable cost even with the shipping. Removal of the 318 item and a side by side comparison reveals that the M3 uses two M12x1.0 ports and the 318 item is one M12 and one M10. I sourced an adapter from Ebay (and unfortunately their international shipping program ugghhh) which is USA made and adapts M12 to M10 bubble flare directly on the master. The other issue is the reservoir from the M3 was filthy and I could not remove the filter successfully to clean it. Ordered a replacement reservoir along with fresh grommets. My alternate plan was to use the reservoir from the 318 but it turns out the retaining screw on the M3 item inserts from the other side making this not possible without machining, who would have thought !! While having both units out I also compared all of the critical dimensions, and successfully confirmed they were a like for like fitment 👍 Disassembly of the M3 master for a full clean, based on what i saw in the reservoir. Can not source replacement seals unfortunately so re-assembled. That's really about it, reassembled everything and bled the system ... happy days !! 3 Quote Share this post Link to post Share on other sites
Cement 913 Report post Posted February 5 One other change I made was to switch out the front pad retention pins from the OEM press fit items to these R-clip style. The OEM system required a ridiculous amount of pounding on the pin to install !! Image shows OEM top and clip based bottom. Quote Share this post Link to post Share on other sites
