Brianr70 83 Report post Posted Friday at 02:08 AM https://www.trademe.co.nz/a/motors/cars/bmw/335i/listing/5136840018 rather interested in this 335i - don't know a lot about them, any to look out for? Quote Share this post Link to post Share on other sites
Danch 37 Report post Posted Friday at 03:05 PM Maybe have a read about N54 engines? 2 Quote Share this post Link to post Share on other sites
Driftit 2112 Report post Posted 17 hours ago It is right in that sweet spot where everything needs doing. Charge pipe will be brittle and will need an upgrade. Waterpump should be looked at being replaced. It will have or soon will have oil leaks from the valve cover, oil filter housing, oil cooler housing, sump and if you are really unlucky the rear main. Coil packs will be on their last legs. PCV will be an upcoming item. Turbo wastegate rattle is common at this mileage. It will no doubt be a trade in. See if any work has been done already. 1 Quote Share this post Link to post Share on other sites
