mystery39 2 Report post Posted June 3 Hi all, Looking for a medium case (188mm) diff in good nick in the range of 3.15-3.25 to fit an E30 - open is fine Or can trade an e36 3.15 LSD for an LSD in the same ratios Thanks! Quote Share this post Link to post Share on other sites
Toast 120 Report post Posted June 5 I've got one but unsure on the ratio, it's open, how much are you looking to pay? Quote Share this post Link to post Share on other sites
elias 387 Report post Posted June 5 2 hours ago, Toast said: I've got one but unsure on the ratio, it's open, how much are you looking to pay? Ratio should be stamped on a metal tag. im assuming @mystery39 is using a zf box in an e30 based on the ratio you’re looking for? in the same boat myself, hoping to find a z3 m coupe lsd for a reasonable price. Quote Share this post Link to post Share on other sites
mystery39 2 Report post Posted June 6 16 hours ago, Toast said: I've got one but unsure on the ratio, it's open, how much are you looking to pay? As little as possible 😁 depends on ratio and condition, $500-1000 at a guess? 14 hours ago, elias said: Ratio should be stamped on a metal tag. im assuming @mystery39 is using a zf box in an e30 based on the ratio you’re looking for? in the same boat myself, hoping to find a z3 m coupe lsd for a reasonable price. Yep - has been the hardest part of this build to track down by far. 1 Quote Share this post Link to post Share on other sites
elias 387 Report post Posted June 6 Yeah I’m struggling to find diff and zf driveshaft. Have most of the rest of the parts. Quote Share this post Link to post Share on other sites
mystery39 2 Report post Posted June 6 Roland Rock has the driveshafts for about 750 from memory. Or an alternative front half shaft/e36 rear half combo for a bit less Feel free to sell me that starter motor when you’re ready 😁 Quote Share this post Link to post Share on other sites
Toast 120 Report post Posted June 6 1 hour ago, mystery39 said: Roland Rock has the driveshafts for about 750 from memory. Or an alternative front half shaft/e36 rear half combo for a bit less Feel free to sell me that starter motor when you’re ready 😁 I'll check on the weekend, there's no tag on it FYI @elias and it's not on hand to spin inputs and count outputs. @mystery39 I've got starter motors too - what are you after? I've got M20 early and late, and E36 ones. Send me a Pm Quote Share this post Link to post Share on other sites
elias 387 Report post Posted June 6 2 hours ago, mystery39 said: Roland Rock has the driveshafts for about 750 from memory. Or an alternative front half shaft/e36 rear half combo for a bit less Feel free to sell me that starter motor when you’re ready 😁 Haha I’ll sell it to you with the flywheel yeah not keen to pay $750 for a front half. @Toast I might be keen to grab a m52 starter off you depending on what you’re after for it. Quote Share this post Link to post Share on other sites
mystery39 2 Report post Posted Saturday at 07:43 AM @elias I bought the alternative front shaft and e36 rear shaft, he wants $550 for the whole thing. Not sure what it’s from, front half is 5mm longer than the 328i one but there is enough room left on the spline so in theory it should work fine. Will find out soon enough 🤷🏻♂️ @Toast after a late m20 starter in good nick if you’ve got one? Cheers 1 Quote Share this post Link to post Share on other sites
elias 387 Report post Posted Saturday at 07:56 AM 12 minutes ago, mystery39 said: @elias I bought the alternative front shaft and e36 rear shaft, he wants $550 for the whole thing. Not sure what it’s from, front half is 5mm longer than the 328i one but there is enough room left on the spline so in theory it should work fine. Will find out soon enough 🤷🏻♂️ @Toast after a late m20 starter in good nick if you’ve got one? Cheers Yeah I think it’s a zf front half from an n52 powered car. Maybe worth looking into. Let me know how you get on! Quote Share this post Link to post Share on other sites
