Petemw812 0 Report post Posted June 10 Hello all, I have a 2003 E46 325ci that has its Airbag light on. I have checked the code and it is 240 for internal fault of the module. Does anyone know if there is someone in NZ who can look at this? I have an image of the module: Look forward to hearing from you, Pete Quote Share this post Link to post Share on other sites
E30 325i Rag-Top 3040 Report post Posted June 10 @Petemw812 has your car had the airbag recall done? It affects most E46s. Give your local franchised BMW dealer a ring they will check your VIN. You MIGHT be able to get it all sorted at same time? Quote Share this post Link to post Share on other sites
paulo 87 Report post Posted June 11 Hi there - if you find that it's the module in the photo that is the problem, let me know - I might have one with the same part number. I am not sure if it would then need to be coded to your vehicle, however. Quote Share this post Link to post Share on other sites
HELLBM 1675 Report post Posted June 11 On 6/10/2025 at 5:59 PM, Petemw812 said: Hello all, I have a 2003 E46 325ci that has its Airbag light on. I have checked the code and it is 240 for internal fault of the module. Does anyone know if there is someone in NZ who can look at this? I have an image of the module: Look forward to hearing from you, Pete Hi Peter. We have replacements @ Hellbm. Can code to the car easily. 2 Quote Share this post Link to post Share on other sites
