Olaf 3426 Report post Posted June 23 Scant info. I know the general line is "Don't". Enquiry from a good friend - hi friend has installed "aftermarket headlights" in his 2011 F20 118i. It's bleating, throwing codes about them. I guess they're making unhappy noises into the CANBUS. What would you folks suggest?? Can it be coded out? Do you need more info about the part? Thanks for your consideration. We have an opportunity to save a non-BMW person from avoiding the Marque forever. Yes I know the PFL F20 was hit with the ugly stick at birth... cheers Olaf Quote Share this post Link to post Share on other sites
M3AN 4192 Report post Posted June 24 Can of worms to be honest Olaf, even changing from halogen to xenon, or xenon to LED with genuine BMW parts is a total nightmare. To know if it were worth the effort one would first need to confirm whether the lights themselves are compatible at all with the Front Electronic (footwell) Module... even getting an authoritative response to that question might be difficult. 1 Quote Share this post Link to post Share on other sites
E30 325i Rag-Top 3043 Report post Posted June 24 As well as physically changing the lights (aka the easy bit) there will be a host of programming and / or electrical changes also required (aka the hard bit). More details on the lights before and after the changes would help a lot. 1 Quote Share this post Link to post Share on other sites
Olaf 3426 Report post Posted June 24 thanks @M3AN and @E30 325i Rag-Top, appreciate your consideration. I'll get some more info and come back. Quote Share this post Link to post Share on other sites
