kerrynzl 3 Report post Posted August 10, 2006 Hey everyone I'm halfway thru my Manual conversion on my E36, I need to know either the dimensions [OD , ID & Width] or part-numbers on the side of the spigot bearing in the back of the crank of a M50 engine If anyone can help with these it will save me a lot of skinned knuckles [& obscenities] as my motor is still on the engine stand Thanks. . . . .Kerry Quote Share this post Link to post Share on other sites
will 169 Report post Posted August 10, 2006 (edited) Kerry NSK bearing 6201 V V C M is what I have used in all m20 I have done. It also fits just about every other early bm motor according to the book. I keep a whole lot here for spares so have taken the part number off one of the boxes and measured actual bearing. According to my vernier.. OD 32mm ID 12mm W 10mm Cost about $6 each max. Will Edited August 10, 2006 by will Quote Share this post Link to post Share on other sites
TronSpec 0 Report post Posted August 10, 2006 (edited) Hey everyone I'm halfway thru my Manual conversion on my E36, I need to know either the dimensions [OD , ID & Width] or part-numbers on the side of the spigot bearing in the back of the crank of a M50 engine If anyone can help with these it will save me a lot of skinned knuckles [& obscenities] as my motor is still on the engine stand Thanks. . . . .Kerry I bought Mine from bindon's up in whangarei. He had a book that had a listing of different bmw bearing's including m50 one's. Had them in stock. SKF brand. Didn't measure it and dont have a part number sorry but I'm sure if you went to any good automotive part or bearing shop they should have them $5 iclud Gst Edited August 10, 2006 by MrHamWallet Quote Share this post Link to post Share on other sites
westy 614 Report post Posted August 10, 2006 15x32x10. OD is the same as is the depth but the ID is 15 not 12,at least for the m52(check your input shaft). Not a common size so I sourced a 15x32x9 from a bearing supplier. BMW part no may be 11211720310 Quote Share this post Link to post Share on other sites
kerrynzl 3 Report post Posted August 10, 2006 HEY GUYS THANKS, Now I can finish wiring the inhibiter tonite & reassemble the trim [or have a quiet nite talking to my missus,"I doubt it"] The ID for my ZF Box is 15mm Again THANKS A LOT KERRY Quote Share this post Link to post Share on other sites
BM WORLD 1296 Report post Posted August 10, 2006 thats the part , just brought one myself , and a couple of m30 type ones as well . hey kerry , when do want to swap that diff over , Quote Share this post Link to post Share on other sites
